1 - 3 of 3 Posts
i just slipped a couple teeth on my timeing belt engine cut out right in my drivway. i replaced timeing belt but car wont start it seems to crank real fast. no compression? not to sure dont have a tester. any help would be greatfull.
Are you sure you're at TDC?
Probably bent some of the valves. You should be able to rent or buy a compression tester at the local parts places.
1 - 3 of 3 Posts
