Hey all. Was a few months ago since I was on here unfortunately. Back in Jan/Feb time the temp gauge was running low raising and lowing from 0-85C then dropping down to 50 then going back up to 85ish constantly. Appeared to be the lower Coolant Temp Sensor. Also the Intercooler had a hole in it and that was replaced.
In the last week half the gauge has started doing something on the other end of the scale. It started to go from the stock 90C and climb to 110,120,125 and drop down to 90/100 and then randomly climb and drop all over the place, a couple of times its gone high enough to flash up the Red STOP sign on the dash.
The coolant level is fine, not leaking, that radiator fan was not going crazy fast like a car overheating or anything either. The Cars efficiency is great still, so I thought as the lower CTS was replaced in Jan/Feb that the other being the same age likely would be the cause. So I picked up one of these and replaced it and it seems to start off a bit better at 90 now and actually gets up the temp faster than it ever used to before the currently issue, so I thought it was solved. But after doing 2 consecutive trips the other day on Saturday it started to rise again, we went out long enough to see if it got the STOP sign to come up but it was hovering more around the 100-120 mark. Red alarm being the 130C.
So only things that come to my low knowledge could be, thermostat/Water pump issue? any other ideas? The radiator fans always turning when the cars engine is running so that's not stopped turning.
I'm a little confused because it doesn't half waiver up and down inconsistently like its a gauge issue because I'd have thought if it was that hot it wouldn't suddenly cool by 10-20C in a few seconds. I don't think the engines burning up because we managed to get back from 100 miles away through country roads and such by alternating the speed we drove at, accelerating or braking up and down hills etc there just seemed to be no pattern at all. Oh yea also, I don't believe the coolant is hot because the expansion/filler tank for the coolant isn't bubbling at all or steaming.
Before I replaced the engine CTS and before this current issue started I'm fairly sure it used to take a while to reach the 90C temp 10-15 minutes I'm 80% sure I remember it taking. With the new CTS in its about 4 minutes to get to 90C.
From reading a few things it seems like the thermostat could be an issue?
Any thoughts would be great to give clues as to how to get this fixed! Thanks!
