1 - 3 of 3 Posts
Have a 2.8 vw passat how many gallons of anti freeze do i need for a complete change? What is compatable to the VW cooling? That is fluid Zerex ,Prestone Audi fluid?
If you drain the block too, buy 2 gallons of pre-mix. I flushed my system out and switched to Peak coolant years ago on all 3 Passats. If you don't drain the block but remove the thermostat housing or water pump, plan on 6L total. For just a drain and fill of the radiator, I would guess just over 4L.
1 - 3 of 3 Posts
