61 - 80 of 98 Posts
Discussion Starter · #61 ·
nope, the intake manifold is one of the last things I'm re-installing... Can't install the hard water pipe when the intake manifold is on. I'm waiting for the throttle body heater hoses (078-121-188-A & 078-121-188-B) and o-ring (N 903 800 02 : 24X3) to install the hard pipe, but I can install the heater core sender hose tonight - waiting for hookup to the hard pipe.. But I can paint the hard pipe tonight!! And clean the throttle body and engine bay... while I wait
Every V6 I've worked on, these were already broken when removing the intake manifold.
Honestly, I've never replaced them.
With all of the screws aligning the intake manifold, it's not a necessity to have them.
Even with those plastic things, you can still shimmy the intake around a bit.
100412
nope, the intake manifold is one of the last things I'm re-installing... Can't install the hard water pipe when the intake manifold is on. I'm waiting for the throttle body heater hoses and o-ring (N 903 800 02 : 24X3) to install the hard pipe, but I can install the heater core sender hose tonight.
That's good. With the intake removed there is a ton of room to get things buttoned up.
After the intake goes on, your pretty much done for.
Unless you've got 'tiny' hands. I don't.
Discussion Starter · #64 ·
Yeah.. I get it... Then like @PZ mentioned, it would truly quality as 'modified'
Speaking of modified...
Back in the day if you saw a vehicle pull up to the light with one of these stuck in the lower corner of a window, you knew that vehicle was for sure modified. :ROFLMAO:
100413
Discussion Starter · #66 ·
The crazy woody the woodpecker logo - yes! Usually saw that on a mopar product in the 70's racing the drag on Long Point pushing 160 mph in a death trap... yeah...
Discussion Starter · #67 ·
Well, no paint booth... but yeah
100416
Reactions: PZ
Noice. (y)
Did the same thing to mine when I did the full rebuild.
100417
Ooooh, purdy! That things looks sexy.
I have those same saw horses. They are HEAVY.
Discussion Starter · #71 ·
Man that’s beautiful... I’m.. I think I’m gonna cry... that’s pretty. But ok, how’d you get it so clean??? Media blasting?? How? I gotsta get me a hoist and engine dolly.
I soda blasted everything you see.
I'll post up some pictures from when I did this rebuild when I get home. At work right now.
Reactions: Rob.Achmann
Discussion Starter · #74 ·
Those corners are sharp too! I had gotten a few lacerations on my legs during that project. :cry:
100420
Reactions: VAGguy
Sorry Rob, totally highjacked your thread.
I should probably start another thread for some of the stuff that I'm going to post.
Discussion Starter · #77 ·
Haha no worries. I love the pics but it’ll just be hard to find when I try to find them again if not in their own post
Discussion Starter · #78 ·
I cannot find the words that can describe my frustration. I waited a week for this part:
100467
that’s the new one. Can anyone see what’s wrong with it? Hold on, let me now show you the original...
100468
can you see now??? Well, let me tell you. The clip in the new one above is designed wrong and off by 90 degrees... I can not install it because the clip will not catch. If I bend the pipe so it does catch, there will be a crimp in the hose. Damn!! I’m losing my mind...Hiw is this possible? Is the 2001 V6 water pipe designed at the angle the replacement part has? Did it change at some point?
Is there anything I can do?
Can you start the thread sideways, push it all the way in and rotate it up? It should catch that way.
Stupid question, did you get the right part number?
The inlet and outlet hoses are NOT the same.
61 - 80 of 98 Posts
