hey everyone,
I've had my Passat (1.8L 2002) sitting for a few years regrettably. but now i'm in the process of getting it going again for my girlfriend to use as a commuter. the car runs fine, I just have a coolant leak, as far as I can tell it's coming out of the thermostat housing, or in that area. I've replaced the thermostat O-ring and its still leaking. when I took the housing off the O-ring was on the inside of the thermostat, common sense tells me it should go on the outside since that's where you don't want the coolant going, maybe i'm dead wrong? does anyone have a diagram of how that area goes together? also, the coolant only leaks once the car has warmed up and the thermostat has opened... that makes me think that the leak is caused by something after the thermostat. maybe someone knows of a common leak that comes from the thermostat housing area? i'm getting pretty close to just using some liquid gasket around that whole housing because I am stumped. if anyone has any ideas, I could use some help. thank you in advance
