1 - 8 of 8 Posts
I’ve just recently got this car handed down to me by my parents. It has been leaking a lot recently and we don’t know why. My dad said there once was a small leak on the hose connect to the top of the coolant reservoir he replaced it. That was to his knowledge the most recent and only leak we’ve had. I ran it today for about 10 min and there was a big puddle underneath. And another thing on the way home the coolant light came on. i was only about a minute away from home so i drove it home and i opened my hood and it was smoking on the left side kinda around the cylinder head. I’m new to cars so i apologize if my explanation isn’t the best. But I’m just wondering if anyone could help me pin down why it’s leaking
Automotive parking light Grille Vehicle Automotive lighting Hood
Hood Automotive tire Automotive lighting Grille Tire
Automotive tire Wood Automotive exterior Bumper Synthetic rubber
Tire Automotive tire Wheel Synthetic rubber Rim
First of all, don't drive it with low coolant or you will soon be replacing the engine or the head(s).
What type of engine do you have (1.8t or V6)? Either engine has its own unique typical places for it to leak so knowing which engine you have is key. But please, don't drive it before you fix the leak.
I just saw the title says GLS. I think that means it's a 1.8t but I'll let those more knowledgeable chime in.
It looks like a 1.8T with the cat next to the exhaust manifold. If so, I expect the coolant flange is failing. There is a writeup in the Info Forum.
You will need to confirm if it's the flange or just the temp sensor seal. The flange is pain to replace.
Discussion Starter · #7 ·
I’ve just recently got this car handed down to me by my parents. It has been leaking a lot recently and we don’t know why. My dad said there once was a small leak on the hose connect to the top of the coolant reservoir he replaced it. That was to his knowledge the most recent and only leak we’ve had. I ran it today for about 10 min and there was a big puddle underneath. And another thing on the way home the coolant light came on. i was only about a minute away from home so i drove it home and i opened my hood and it was smoking on the left side kinda around the cylinder head. I’m new to cars so i apologize if my explanation isn’t the best. But I’m just wondering if anyone could help me pin down why it’s leaking View attachment 107116
I found out it’s leaking from the thermostat housing
That's a pretty easy one to do. Just remove the intake hose and you should be able to get to it without too much trouble. I recommend a new housing and new thermostat while you are in it.
You'll need to drain most of the coolant to do it. There is a drain at the bottom of the radiator next to the driver side fog light. Just pull off the fog light grill and it is behind the rubber flap towards the center.
1 - 8 of 8 Posts
