I took the nose off the car and pretty much drained all of the coolant out of the car except what was in the heater core.
I filled up roughly 7 quarts of 50/50 G13/water and it appears that theres coolant everywhere except the upper water pipe (when I squeeze the upper radiator hose I just hear air in the reservoir)
I exposed the bleeder valve on the heater hose and left the reservoir cap off but the coolant level isn't going down.
I am afraid to drive it but when it idles it sits steady at 190. I just replaced the thermostat so I know that's not the issue.... but it does appear that my problem is because the thermostat isn't opening.
The water pump was replaced at 75k, my car's at 100k.
How can I get the air out of that upper pipe? I don't have a fancy coolant evacuation system tool thing.
Thanks!
Thanks!
