I would like to know the consequences of not replacing the cam tensioner gasket. I am about to replace the whole pcv system and the valve cover gasket due to oil leaks caused by bad check valve. My car is at 191,000 miles and I want to do enough work to keep it on the road for the next 10,000 - 20,000 miles. So far I have replaced the timing belt, water pump, thermostat, and gas pump. I got this car at 170,000.
If the only problem with a bad cam tensioner gasket is the oil leak can I just keep an eye on the oil level and add oil as needed? and also make sure that no oil is making it's way to the spark plug wells? I would do the cam tensioner gasket replacement myself but I have not found a good write-up on it. By the way, I have a 2002 1.8t AWM.
Thanks!
Thanks!
