My CEL and 'emissions workshop' came on the other day. I pulled the code with OBDII and got 'P1539 clutch vacuum vent valve switch - incorrect signal'. Anyone know what this is? I have put on a few hundred miles since clearing it (I had the code a few months ago & cleared it....it took about 5k miles to come back) Just curious if its a BS code or something I should look into. Thank you all!
-Phil
Scott....Rpm's tend to bounce a bit when shifting at times (but at idle it will bounce up & down little too....may be a whole other problem) I need to pick up a Bentley. Are the switches accessible from under the dash?? Thanks!
