1 - 20 of 26 Posts
That is the sound I hear when I go into my laneway on an angle. Clunk, clunk. Straight bumps no noise. Angles = clunk. Front end.........
HELP.
I am doing my spring swap this week. I would like to tackle this while I am in there if possible.
What drives you to that conclussion. No noise when turning and driving. No grinding noises at all. I had allways thought that was CV????? I was thinking sway bar links???? That would give me the one wheel only noise. If both wheels hit bump at same time I don't think there is any clunk at all. Maybe strut bearings??? I just don't want to hear control arms. I want to dial it in fast cause I will change the strut bearings with the springs if that is the cause.
I just had that fixed last Monday - clunking when I turned left and accelerated. Only on the left wheel. Got progressively worse.
Left CV joint. Right CV went out 6 months before.
yeah, that is what I thought. This is not under acceleration. It is slowly rolling into my laneway.
You are not alone. I know what you are talking about, I just experienced the same thing while turning into a parking lot. It is not the CV joint. But I have no idea. :nervous:
It sounds like the sway bar links (if they are the old style).
ronniebaldino said:
2000 1.8t variant
I have a 2000 sedan. How many miles do you have on it? I just had my left tie rod end changed a month or 2 ago because I had a clunk too. Same as you, only while turning left into a bump or curb. Also, steering reponse improved dramatically after replacement.
Discussion Starter #15
Well, I just tried to replace my springs (more on this in another post) and I found my clunk. Upper control arm ball joints are kinda loose. There is enough play in them that I can move the tire and watch the joint slop around. That ain't normal is it? What now. It looked like it was getting bad on the other side as well.
I have time left on my limited warranty. Probably not covered though is it?
I have 114 000 km.
Do I replace the ones that are definetly busted or the whole bunch?
Discussion Starter #18
loose and everytime i fix it I get my oil changed and it gets put back on half assed. I can't beleive that the clunk is just my skidplate???
I definetly have play in my upper control arm ball joints. How much is normal? should I be able to move my tire?
I guess I can drop by the dealer and get some new clips for it and see what that does. I really want to know what to do with the arms though as I will have to get the whole thing apart anyway.
There should be no play in the ball joints. Replace them. You can get a set (all 8) from ECS
for almost the same price as 4 individually. It is best to do them with the suspension as half
of it comes out for the spring change.
There should be no play in the ball joints. Get as many replaced as the warranty will cover. If they won't cover them try an independent shop. I just replaced 5 of them at a cost of $1200 You could try it yourself if you want.
1 - 20 of 26 Posts
