1 - 7 of 7 Posts
Hey I have a problem:
I have a 99 v6 passat and when I turn it on, the climatronic screen starts blinking and it stops like in 2 minutes
The car also doesn't colds anything it needs a gas charge but the guey that is puting the gas charge told me thet that's another problem can anyone please tell me?
Thanks ;)
My car did something similar a couple years ago after dealer service of the a/c. The gas pressure was too high - dealer put too much gas into the system. All was OK after dealer reduced the gas pressure.
No display problem before the recharge - just wasn't cooling properly. Display problem started immediately after gas recharge. Cooling was OK after finally reducing the recharge pressure and the display blinking problem has never happened again.
hmm, this is handy to know. Makes sense though, Climatronic has it's own diagnosis function so it must be aware when there's a problem with the gas pressure.
yesterday they were finding if there was any lack or leack of air and put some air into the a/c lines and the climatronic stopped blinking I think that this thing advices if theire's any problem that's why
Definitely have a problem - all VW Climatronics blink on startup if there is a fault code. If it all atually functions correctly, my guess would be a sticky flap motor. Get it VAG-Comd - if it is just a flap, dont worry too much about it.
You can actually search the forums for a climatronics 'secrets' - hold down recirc and up temp (or something) which puts it into diagnostics mode just for the climatronic system - your web search will also provide you with a list of fault codes - so you could even check it out yourself if you want.
1 - 7 of 7 Posts
