All the lights come on in my interior except my panel for the climate control knobs and buttons ( I have the manual one) Is it connected to a fuse or does all the leds blow at the same time in that panel :???:
Pull the middle knob out with pair of pliers (using cloth as not to scratch). The bulb is there. You will need piece of tubing to pull the bulb out. Replacement bulb is $2.00 at the dealer.
You may try to wiggle the bulb first. It may just have bad contact.
Do I just yank out the middle knob or do I have to set it to a certain position? When I put on the air, the recirculation button and the ac button light up when I push them in :???: The only ones that don't light up is the round knobs :crazy:
Each button has it's own light. (That's why they work.) The knobs are all lit up by the bulb behind the fan dial. The knob does not have to be in any particular position to remove it.
SirWired
