When the car is on/turned to on with the engine off it clicks been j remove my key there is a long whining noise. The whining noise is at the end of the video. So listen closely. Use headphones if you must. And now just today it started clunking and then bucking when I put it into any drive gear.
My step dad got home in time to look at it. It drives and shifts smoothly which is good, but it needs the transmission checked. He said it could just be low and or need to be flushed out. But here's he bigger problem, that clunking is my engine flying up :O it needs new motor mounts.
