1 - 8 of 8 Posts
There is a specific spray cleaner for MAFs. I have a can to clean mine. I just haven't cleaned it yet. As for electronics cleaner, it may have too much pressure for the thin wires to handle.
Why is it a softer spray? Who told you that? Did you u tube it?
Can electronic cleaner be used to clean mass air flow sensor?
Maybe, but MAF cleaner isn't expensive and a new MAF isn't cheap. I'd just pay the few $ and do it right rather than take the chance.
Otherwise, I have no idea what are the differences between MAF cleaner and some generic electronics cleaner.
I don't know about a pressure difference, but it is likely.
Also most electronics cleaners contain lubricant, a MAF sensor wouldn't like that.
I doubt that anyone but a fake would even consider it.
Discussion Starter · #6 ·
What about CRC QD Electronic Cleaner? I had MAF cleaner but i can not find it .
2001 B5.5 Volkwagen Passat GLX
I used CNC MAF cleaner, would recommend. I spent $8 at walmart for CRC Twin pack which had the MAF cleaner and throttle body cleaner. If it were me and I didn't have a spare MAF sitting around, I personally wouldn't risk it with those electronics cleaners. Maybe, just maybe with isopropyl alcohol, but the pressure is what is usually being used to help clean
I was always under the impression the MAF cleaners were specifically designed to evaporate quickly so they don't get the engine, and sensor "safe" mainly so they don't set off the O2 on the way out if they do. So some sort of ether, like starting fluid. But the whole pressure thing makes sense. fwiw.
1 - 8 of 8 Posts
