1 - 19 of 19 Posts
G
2006 Porsche Ruf RGT
Engine Location: Mid
Drive Type: Rear Wheel
With limited slip differential
Weight 1432 kg | 3157.6 lbs
Performance
0-60 mph: 4.2 seconds.
Top Speed: 197 mph
Engine
Engine Configuration 6
Engine Dry-sump lubrication
Aspiration/Induction Normal
Displacement 3.80 L | 231.9 cu in. | 3800.8 cc.
Horsepower 445.00 HP (327.5 KW) @ 7600.00 RPM
Torque 420.00 Ft-Lbs (569.5 NM) @ 5100.00 RPM
HP to Weight Ratio 7.1 LB / HP (Vehicles with similar ratio)
HP / Liter 117.1 BHP / Liter
Bore 102.00 mm | 4 in.
Stroke 76.50 mm | 3 in.
Compression Ratio 12.0 : 1
Fuel Type Gasoline - Petrol
Standard Transmission Gears 6
Transmission Manual
Fender flares are horrible. :thumbdown ...I'll just stick with the R12, thanks.
Salty Moderation Stylez
Yeah, Nissan Frontier called and wants its fender flares back.
Nice!!!
I used to have one of those Frontiers. I actially kinda miss it. Although with the Supercharger it would break free out back ALL the time ;)
Unless it's an enlarged version of the 997 GT3 motor then it's not a true dry-sump motor.
im 16 years old, if i drove that, do you have any idea how many times i would get laid, god just thinking about it makes me want it
You'd be finished before you even pulled yourself out of the seat.
lol, it better have a lsd. funny how the OP put that in the 3rd or 4th line of the post. sounds almost like advertising for an econobox.
Otherwise I like it overall. Looks very menacing with the huge wheels and aggressive bodywork. its not like it doesn't have the performance to back it up either. i dont think id complain if the wing was twice as big :p The flare rivets give it a cheaper aftermarket look. You'd think RUF would be capable of making it look more oem with the usual higher price they'd prob charge.
whats really interesting is that its making around 445hp and 420tq, from a 3.8l. At first I thought it must have been a turbo car, but then i read its n/a. thats pretty awesome that RUF is not relying on forced induction. that motor must be pretty well built to be making those power figures even at a 12:1 comp. ratio!!!
Overall I love it. It would be 'class' just for the engine alone imo.
Also:
In December 2006 RUF presented the RUF RGT at the Essen Motor Show - a light weight Coupe built around a high-revving natural aspirated engine that is based on the 997 when it comes to technology. RGT stands for RUF GT. The RGT is the perfect piece of sports equipment for the street and the race track. Two body styles of the RGT are available - the coupe and the cabriolet.
A prominent aerodynamic feature at the front of the RGT is the bumper with the five air intakes. Incoming air through the big air intakes on the outside and in the centre flows against the water coolers of the engine. Two additional small air intakes channel the air to the brakes. A black narrow vent is located ahead of the front deck lid. Incoming air is channelled through the centre radiator. The aerodynamically optimized exterior mirrors are electrically adjustable and heatable. The mirror base and housing are available upon request in carbon fibre. The two aluminium doors with integrated side protection bars save 14 kilograms. Wider glass fibre fender flares screwed to the body allow the use of bigger wheel and tyre combinations. In addition, they can be replaced budget-priced in case of repair. The rear lid painted in body colour with the adjusted duck tail consists of Kevlar Carbon fibre. The rear spoiler that is mounted to the duck tail is made of visible Carbon fibre.
Two oval exhaust end pipes open out through two outlets in the rear bumper.
The high revving normally aspirated engine is based on the crankcase of the 964 engine generation. It is equipped with dry-sump lubrication with a separate oil tank to ensure a reliable oil supply for the engine even at high cornering speeds. The 3.8 litre sports engine has a high compression ratio of 12.0 : 1. The out put of 445 hp (327 kW) is reached at 7,600 rpm. The maximum torque of 420 Nm abuts at the crankshafts at 5,100 rpm. The RGT is equipped with the variable camshaft system. This enables an optimization of power, torque and consumption across the complete power band by a rotation speed dependent and load-dependent adjustment of the intake camshafts. The variable aspirated engine features two resonance flaps to balance the air for an ideal filling of the cylinders. The connecting rods are made of light, high-strength titanium. A digital engine electronic, i. e. a motronic with drive by wire, undertakes the task of engine management. The RGT engine captivates by its spontaneous response behaviour and its distinct revving ability.
The RGT will exclusively be delivered in rear-wheel-drive and 6 speed transmission with limited slip differential and short shift kit.
The independent front suspension combines McPherson struts with aluminium links. The strut suspension forms a unit with the front axle cross member, the sway bar and the steering gear. The rear axle assembly consists of sub frame-mounted multi-link suspension, featuring LSA construction. This design is another important factor in the car's responsive driving dynamics. The sports suspension is adjusted for road traffic as well as for track use by the help of especially adjusted Bilstein gas shock absorbers and chassis springs.
The brake system consists of red-painted monobloc callipers and ventilated, cross drilled brake discs. The monobloc callipers are made of one piece. The front discs measure 350 millimetres in diameter with 6 piston brake callipers. The rear brake discs have a diameter of 330 millimetres and 4 callipers. The RGT is serially equipped with a stability management with ABS, ASR and ABD. For an extra charge we also offer a Ceramic-Composite brake system.
The three-piece 19 inch Superleggera aluminium wheels are equipped with a very light forged centre piece. The front wheels have a width of 8.5 inch and the rear wheels 12.5 inches. Tyres of 235/35 ZR 19 are mounted in the front and 325/30 ZR 19 in the rear. As an option, forged, single-piece 20 inch aluminium wheels in classis RUF 5-spoke-design are also available.
The interior of the car is serially equipped with black light-weight items, sport seats and six airbags. To reduce weight, the rear seats are missing. An airbag sports steering wheel, an aluminium leather shift knob, aluminium pedals and foot rest are mounted in the passenger compartment. In the cockpit of the RGT the adapted RUF instruments with green scaling stand out. The analogue speedometer reaches 230 mph (370 kph). The equipment is rounded off by an air conditioning, the Communication Management System with colour screen and sound system. The headliner of the RGT is covered with anthracite Alcantara. The standard RGT Coupe is equipped with an integrated roll cage which is covered almost entirely by the Alcantara of the A, B and C pillar. A crossbar, which can be demounted when the rear is to be used, is connected to the bar behind the B pillar. By request, the RGT can be manufactured with rear seats or with an individually designed luggage rack.
Zero to 62 mph (100 kph) takes just a scant 4.2 seconds, zero to 125 mph (200 kph) just 13.5 seconds. The top speed is 197 mph (315 kph).
1 - 19 of 19 Posts
