While fooling around with my wife's B5 I disconnected the plugs that go to the ignition amp and the MAF. When I did so I forgot to disconnect the battery. After plugging everything back up the CEL is on and the idle is very rough. I tried disconnecting both battery cables from the battery and shorting the two out together (not touching the battery) to reset the computer. I don't think it reset the computer because everything is still the same. How do you reset the computer? Is there a fuse I can pull? Anyone in or near Anaheim have a code reader to see what codes it showing? Thanks in advance. :bow:
-Mike
