i installed a k&n filter and the check engine light came on. so i took it to auto zone and it is the mas air flow sensor. can anyone help......
It sounds as if the MAF sensor is fouled & probably need a new one. I would recommend getting it scanned with someone or a Dealer with a VAG-Com to make sure it is the MAF before you spend $ on the part. I assume Autozone used the generic OBDII scanner wich should be pretty accurate but I would make sure....20vbruster said:yes they cleared the code yesterday and today after about an hour of driving it came back on.
I never heard of using the 2.0 MAF ..... anyone heard of this? Maybe it's possible without problem? Could you leave the bad MAF in...sure, but down the road you could run into a lean or rich fuel concern with the bad MAF. I'm not sure about cleaning the sensor or what you would use to clean it....I'm sure someone will chime in about that. Good luck with it.20vbruster said:i don't notice any difference in the driving of the car. no hp losses no rough ideling. i guess the question is will it hurt to leave the MAF , if so what will the damage be. could i just clean the MAF?
If the oil from the K&N caused the check engine lamp the paper filter will prevent future check engine lamps caused by that but first you need to clean/take care of the problem.....check this link out Natskiboy suggested:20vbruster said:if i switch back to the paper filter will the check engine light go away?
it still doesn't post all of the pics.2000PASSAT20V said:If the oil from the K&N caused the check engine lamp the paper filter will prevent future check engine lamps caused by that but first you need to clean/take care of the problem.....check this link out Natskiboy suggested:20vbruster said:if i switch back to the paper filter will the check engine light go away?
http://www.clubb5.com/forums/viewtopic.php?t=57334&sid=b787e53b717cf65630132e17a22e3aae
http://www.clubb5.com/forums/viewto...af+clean&sid=b787e53b717cf65630132e17a22e3aae
