After reading quite alot of topic's on airfilters recently on the forum i thought i would buy a new Pollen filter and airfilter as my local accessories shop was doing buy one get one free, wasn't sure i would need them straight away as i had only brought the car 8 weeks ago (7 1/2 weeks off the road due to accident) and the car dealer supposedly gave the car its 80k service inc timing belts. So had a look this afternoon, took the pollen filter out and i think its the vw original filter as fitted in 1998, it was black to say the least and clogged up with leaves and allsorts, fitted the new one and tested the climate control and the airflow from the vents is like 100 times better. So thought i would look at the air filter, humm definitely not changed on the service, very clogged up and definitely not from the 100 or so miles i have driven since buying it, not driven the car since so not sure if its breathing any better for the change.
Checked in the Haynes manual and it says in the service schedule that the pollen filter should be changed every 20k and airfilter every 40k and as the car has just supposedly had its 80k service both should have been done. Now i am wondering whether they actually did the timing belt, i have it in writing that they have and have a years warranty if it should snap, but is there any simple way of checking that the belt is pretty new at all, what should i be looking at??
So i would advise you all to check your pollen and airfilters after a service, just to see if they have been done, i suppose i better check the spark plugs and all the other stuff it says for the 20 & 40k services to see if they have been done.
