1 - 15 of 15 Posts
2000 Passat 1.8T 74k miles ATW engine code.
I get a P1128 Manufactures Controlled Fuel and Air Metering when I check the codes. I also get the "Emissions Workshop" message at startup.
Additionally I noticed that my boost is peaking at only 5 psi or so. Is this soft limp mode?
I searched the forums and have pretty much come to the conclusion that it's a bad MAF. Can anyone confirm this before I drop $140 on a new MAF?
TIA
Chris
You could run a vag-com scan on the maf readings to confirm it. Always double check the vacuum hoses as they can cause the same problem.
You should be able to get a rebuilt maf from the dealer for less than $100. I did when I had my ATW.
I've check the vac lines and replaces a few of them. If I clear the code, it drives normal, with the correct level of boost for about 20 miles, then the CEL comes back on.
I just picked up a MAF from the dealership over my lunch, $141, not too bad.
I'm going to swap it in this evening and see how it goes.
Discussion Starter · #7 ·
Well the MAF is in the front seat of my car waiting for things to cool off under the hood. I'll let you know what happens.
Did you notice a loss of boost as well?
Oh and it's re manufactured.
the car has almost no power, new vacuum hoses, new filter, new o2 sensor front and rear
the funny thing: i took the car to the dealer for diagnostics and the say it's not the maf, it's A LEAK ,god knows where...
i called ADVANCE, PEPBOYS n AUTOZONE in my area, they do not have any refurb in stock(special order, one to 2 weeks)
Discussion Starter · #12 ·
Well I replaced the MAF tonight, cleared the code and went for a drive. My boost is BACK! and no cell yet, I'll know for sure tomorrow when I go on the Saturday Home Cheapo run.
Mine 2000 ATW(45,000 mi.) is doing the same thing, I got some cleaner for the MAF, any gave it a cleaning...we'll see if it works...
i bought brand new bosh maf from ebay and voila the CEL is gone
i drove the car for 80 miles city and highway and it never showed up.
before that i cleaned it (maf) couple times, but CEL comes back in about 25 miles of driving
1 - 15 of 15 Posts
