1 - 2 of 2 Posts
2009 Passat Wagon
Hi there,
I recently had my 2.0T 09 CCTA passat stall out at idle multiple times with no CEL. I pulled a few codes and booked an appointment at the mechanic. Codes were fuel mix and MAF implausible signal and oxygen (lambda) too rich/intermittent, ECM Power relay opens too.
The next day i had the CEL and EPC light come on. This time i saw throttle angle and position faults. Car went into limp mode.
Wondering if anyone has any thoughts on this?
7 Faults Found:
001674 - ECM Power Relay Load Circuit
P068A - 000 - Opens Too Early - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Date: 2047.15.31
Time: 31:63:63
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 96.0°C
Temperature: 42.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 9.017 V
000257 - Mass Air Flow Sensor (G70)
P0101 - 000 - Implausible Signal
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 156640 km
Time Indication: 0
Date: 2043.14.12
Time: 11:27:03
Freeze Frame:
RPM: 2164 /min
Load: 11.8 %
Speed: 74.0 km/h
Temperature: 91.0°C
Temperature: 27.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 14.224 V
000370 - Fuel Trim; Bank 1
P0172 - 000 - System Too Rich - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 156644 km
Time Indication: 0
Date: 2043.14.12
Time: 11:32:24
Freeze Frame:
RPM: 2541 /min
Load: 27.4 %
Speed: 87.0 km/h
Temperature: 90.0°C
Temperature: 31.0°C
Voltage: 14.097 V
008817 - Oxygen (Lambda) Sensor Signal B1 S2
P2271 - 000 - too Rich - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 156650 km
Time Indication: 0
Date: 2043.14.12
Time: 11:37:37
Freeze Frame:
RPM: 1873 /min
Load: 11.4 %
Speed: 26.0 km/h
Temperature: 98.0°C
Temperature: 39.0°C
Voltage: 13.970 V
P0172 - 000 - System Too Rich - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 156666 km
Time Indication: 0
Date: 2043.14.12
Time: 13:31:34
Freeze Frame:
RPM: 755 /min
Load: 34.5 %
Speed: 0.0 km/h
Temperature: 93.0°C
Temperature: 33.0°C
Voltage: 13.970 V
000289 - Throttle Position Sensor (G69)
P0121 - 000 - Implausible Signal - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 156674 km
Time Indication: 0
Date: 2043.14.13
Time: 10:55:22
Freeze Frame:
RPM: 874 /min
Load: 64.3 %
Speed: 0.0 km/h
Temperature: 66.0°C
Temperature: 18.0°C
Voltage: 14.224 V
000545 - Angle Sensor 2 for Throttle (G188)
P0221 - 000 - Implausible Signal - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 156674 km
Time Indication: 0
Date: 2043.14.13
Time: 10:55:22
Freeze Frame:
RPM: 874 /min
Load: 64.3 %
Speed: 0.0 km/h
Temperature: 66.0°C
Temperature: 18.0°C
Voltage: 14.224 V
Passat B6 Variant/Wagon 09
1 - 2 of 2 Posts
