motor mounts or snub mount, look underneath for any purpleish or oil colored (if you have newish meyle mounts) goo from bottom of motor mounts.
There was a huge discussion on this here, a couple of years ago. Basically, they all do it to some extent. What's happening is the transmission drags on the engine at idle, where the engine isn't making much power. The older the transmission, and the poorer the engine is running, the worse it is.My 98 passat 1.8t when at a red light it vibrates a lot while on drive, so I put the car in neutral and the car idles perfect, anybody know what could it be.
Exactly what I was talking about, idling in drive while stopped.the car doesn't shake or vibrate @ idle it does it on drive as soon as you put it on neutral or park it idles normal but it does sound like the motor mounts could be the winner i'll check them tomorrow thanks guys
That made the biggest improvement on mine, as well. Replacing the motor mounts did little-to-nothing.I reduced this on my 99 v6 by changing the transmission fluid.
