Ok so I was doing a few things on my car today, I changed the console to a B5.5 console so I disconnected the negative terminal of the battery while I was working on it believing some ABS modules might have been in the vicinity of where I was working. I don't have the B5.5 ebrake handle and I haven't modded my ebrake yet so I just left the ebrake off, I only use it when I park anyway so I'll leave it off until tomorrow when I mod mine to fit. So I put everything back together and connect the battery. I bought a Vag-com connector on ebay a month ago and decided to try it out tonight. I grabbed my printed manual and my laptop with vista and my connector
I had downloaded and installed vag-com 3.11 so it didn't have a USB choice in the options to test. So then I downloaded 4.09 and installed followed the manual except when I plugged in the USB and windows searched for the drivers it didn't find any. I opened vag-com and options, checked USB and clicked test and it sat for 10 mins not doing anything. I tried to cancel the test but it wasn't responding, then I tried to close the program also not responding. So as usual I shut down my laptop and disconnected the cable. Then when I turned the car on just to make sure everything was OK it was acting funny. When I crank it starts but it doesn't fire right up it falters as if it's going to stall and then it fires up. Then the engine rpms are bouncing around up and down usually three times before settling down. If I rev the engine and then let off to idle the same thing it sounds like it's going to stall then it revs to about 1000 - 1100 then back down three tims then settles. My question is with my connector and vista which version of vag-com do I need? and has anyone ever experienced this before and what should I do to get things back to normal? any suggestions will help.
PS
it's a 99 AEB B5
PS
it's a 99 AEB B5
