Tuesday,16,May,2017,23:28:27:15629
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 17.1.3.0 (x64)
Data version: 20170320 DS267.7
Ross-Tech: Home
VIN: WVWJK73C68P001749 License Plate:
Mileage: 207610km-129002mi Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 52 53 56 62 72
VIN: WVWJK73C68P001749 Mileage: 207610km-129002miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
1C-Position Sensing -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Sporadic communication error 1000
72-Door, Rear Right -- Status: Sporadic communication error 1000
Address 01: Engine Labels: 06F-907-115-AXX.clb
Part No SW: 3C0 907 115 S HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0020
Revision: 5BH16--- Serial number: VWZCZ000000000
Coding: 0404010A19070160
Shop #: WSC 08284 444 58853
VCID: 306F338FA31E5EC159-8064
6 Faults Found:
001152 - Coolant Fan Control Circuit 1
P0480 - 002 - Electrical Malfunction - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 206412 km
Time Indication: 0
Date: 2017.03.19
Time: 20:38:01
Freeze Frame:
RPM: 844 /min
Load: 24.3 %
Speed: 0.0 km/h
Temperature: 87.0°C
Temperature: 59.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 10.033 V
004372 - Oxygen (Lambda) Sensor; B1 S2
P1114 - 008 - Internal Resistance too High - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 206412 km
Time Indication: 0
Date: 2017.03.19
Time: 20:38:01
012555 - Low Pressure Fuel regulation
P310B - 004 - Fuel Pressure Outside Specification
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 3
Reset counter: 255
Mileage: 207287 km
Time Indication: 0
Date: 2017.05.01
Time: 16:35:41
Freeze Frame:
RPM: 858 /min
Load: 27.8 %
Speed: 3.0 km/h
Temperature: 73.0°C
Temperature: 38.0°C
Voltage: 8.509 V
000135 - Fuel Rail/System Pressure
P0087 - 002 - Too Low - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 255
Mileage: 207287 km
Time Indication: 0
Date: 2017.05.01
Time: 16:35:41
001378 - System Voltage
P0562 - 002 - Too Low
Freeze Frame:
Fault Status: 01100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 207611 km
Time Indication: 0
Date: 2017.05.16
Time: 01:39:13
Freeze Frame:
RPM: 836 /min
Load: 24.3 %
Speed: 0.0 km/h
Temperature: 69.0°C
Temperature: 38.0°C
Voltage: 9.779 V
004688 - Fuel Level too Low
P1250 - 008 -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 207611 km
Time Indication: 0
Date: 2017.05.16
Time: 01:39:13
Readiness: 0110 0101
Address 02: Auto Trans Labels: 09G-927-750.clb
Part No SW: 09G 927 750 HJ HW: 09G 927 750 HJ
Component: AQ 250 6F 1068
Revision: 00H69000 Serial number:
Coding: 0000584
Shop #: WSC 00028 028 00001
VCID: 000FA34F533E0E41E9-8054
2 Faults Found:
01314 - Engine Control Module
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 2
Fault Frequency: 9
Reset counter: 0
Mileage: 0 km
Time Indication: 0
00364 - Terminal 15 Slave
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 9
Reset counter: 0
Mileage: 0 km
Time Indication: 0
Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 D HW: 3C0 614 109 D
Component: J104 C4 440 V2 0003
Revision: --020--- Serial number: 00000775293037
Coding: 0000348
VCID: 1F4DC033CE80D1B9F0-804A
2 Faults Found:
01542 - Yaw Rate Sensor (G202)
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 9
Reset counter: 222
Mileage: 207611 km
Time Indication: 0
Date: 2017.05.16
Time: 01:16:51
Freeze Frame:
Speed: 0.0 km/h
Hex Value: 0x0002
Voltage: 10.75 V
Bin. Bits: 00111110
Count: 170
00532 - Supply Voltage B+
Freeze Frame:
Fault Priority: 3
Fault Frequency: 9
Reset counter: 222
Mileage: 207611 km
Time Indication: 0
Date: 2017.05.16
Time: 01:16:51
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No SW: 1K0 820 047 GG HW: 1K0 820 047 GG
Component: Climatic PQ35 141 0909
Revision: 00141027 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 6FEDF0F37EA0013900-803A
1 Fault Found:
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 AE HW: 3C0 937 049 AE
Component: Bordnetz-SG H52 2002
Revision: 00H52000 Serial number: 00000004892646
Coding: 00848F0340041A00470000000F000000000854415C0001
VCID: 6CD7E7FF4FB6FA2125-8038
Subsystem 1 - Part No: 3C1 955 419 A Labels: 1KX-955-119.CLB
Component: Wischer 230407 003 0205
Coding: 00046997
Shop #: WSC 00028
9 Faults Found:
01504 - Bulb for License-Plate Light (X)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01111100
Fault Priority: 2
Fault Frequency: 97
Reset counter: 222
Mileage: 199129 km
Time Indication: 0
Date: 2016.08.15
Time: 12:28:00
Freeze Frame:
ON
Voltage: 12.90 V
ON
ON
OFF
OFF
ON
01117 - Generator Terminal DF Load Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 97
Reset counter: 222
Mileage: 199129 km
Time Indication: 0
Date: 2016.08.15
Time: 12:28:00
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 5
Mileage: 207555 km
Time Indication: 0
Date: 2017.05.14
Time: 14:20:00
Freeze Frame:
ON
Voltage: 17.00 V
ON
ON
OFF
OFF
OFF
00978 - Lamp for Low Beam; Left (M29)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 5
Mileage: 207555 km
Time Indication: 0
Date: 2017.05.14
Time: 14:20:00
00979 - Lamp for Low Beam; Right (M31)
Freeze Frame:
Fault Status: 01101010
Fault Priority: 1
Fault Frequency: 254
Reset counter: 222
Mileage: 199101 km
Time Indication: 0
Date: 2016.08.14
Time: 01:27:00
Freeze Frame:
ON
Voltage: 13.40 V
ON
ON
OFF
OFF
OFF
01333 - Door Control Module; Rear Left (J388)
Freeze Frame:
Fault Priority: 1
Reset counter: 222
Mileage: 199101 km
Time Indication: 0
Date: 2016.08.14
Time: 01:27:00
01334 - Door Control Module; Rear Right (J389)
Freeze Frame:
Fault Priority: 1
Reset counter: 222
Mileage: 199101 km
Time Indication: 0
Date: 2016.08.14
Time: 01:27:00
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 1
Reset counter: 222
Mileage: 199101 km
Time Indication: 0
Date: 2016.08.14
Time: 01:27:00
02383 - Windshield Wiper Motor Function Restricted due to Under-Voltage
Freeze Frame:
Fault Priority: 1
Reset counter: 222
Mileage: 199101 km
Time Indication: 0
Date: 2016.08.14
Time: 01:27:00
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 N HW: 3C0 909 605 N
Component: 17 AIRBAG VW8R 032 2522
Revision: 13032000 Serial number: 003B2P820RWO
Coding: 0012599
VCID: 3169368BA81457C956-8064
Subsystem 1 - Part No: 3C0 959 339 B
Component: BF-Gewichtsens. 007 0003
Subsystem 2 - Serial number: 0000000003LQQR
Subsystem 3 - Serial number: 0001.01.000000700000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†6332MSME1A244A63Bÿ†63
Subsystem 5 - Serial number: 44A63Bÿ†6342MSME19431E206ÿ†63
Subsystem 6 - Serial number: 31E206ÿ†6351HTS66HBGTLR6Dÿ†63
Subsystem 7 - Serial number: GTLR6Dÿ†6361HTS66HBGHNO61ÿ†63
Subsystem 8 - Serial number: GHNO61ÿ†63727TS6OFJSKLS6Yÿ†63
Subsystem 9 - Serial number: SKLS6Yÿ†63827TS6OFJOK6C60ÿ
Subsystem 10 - Serial number: OK6C60ÿ
1 Fault Found:
03032 - Supply Voltage for Seat Occupied Recognition Control Module
Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
Part No SW: 3C0 953 549 J HW: 3C0 953 549 J
Component: Lenksäulenmodul 006 0010
Revision: 00006000 Serial number: 3C5953507BE
Coding: 0001013
VCID: 33653C83520865D924-8066
No fault code found.
Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
Part No SW: 3C0 920 971 F HW: 3C0 920 971 F
Component: KOMBIINSTRUMENT VD1 1216
Revision: V0002000 Serial number: 00000000000000
Coding: 0005205
Shop #: WSC 08284 444 82896
VCID: 285FDBEF9BCE160181-807C
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 7
Mileage: 207295 km
Time Indication: 0
Date: 2017.05.01
Time: 17:06:40
00447 - Function Limitation due to Over-Voltage
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 5
Mileage: 207554 km
Time Indication: 0
Date: 2017.05.14
Time: 14:19:41
Address 19: CAN Gateway Labels: 3C0-907-530-V2.clb
Part No SW: 3C0 907 530 E HW: 3C0 907 951
Component: J533__Gateway H10 0080
Revision: H10 Serial number: 1200P075020388
Coding: FD807F060012021002
VCID: 2345CCC3E2E8F559D4-8076
2 Faults Found:
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 244
Mileage: 207354 km
Time Indication: 0
Date: 2017.05.06
Time: 19:59:21
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 244
Mileage: 207354 km
Time Indication: 0
Date: 2017.05.06
Time: 19:59:21
Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
Part No SW: 3C0 919 965 HW: 3C0 919 965
Component: Kompass 005 0003
Revision: 00005000 Serial number: 1166279TRFZH06
VCID: 6DD1EAFB74ACF32932-8038
Address 25: Immobilizer Labels: 3C0-959-433-25.clb
Part No SW: 3C0 959 433 AK HW: 3C0 959 433 AK
Component: IMMO 051 0383
Revision: 00051000 Serial number: VWZCZ000000000
Shop #: WSC 08210 444 100847
VCID: 73E5FC83128825D9E4-8026
Subsystem 1 - Part No: 3C0 905 861 J
Component: ELV 029 0380
3C0905861J ELV 029 0380
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.clb
Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
Component: J386 TUER-SG FT 1131
Revision: 32008001 Serial number: 00000610378508
Coding: 0001205
VCID: 3B7514A37A58AD99FC-806E
1 Fault Found:
00932 - Electric Window Motor; Drivers Side (V147)
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 3
Fault Frequency: 2
Reset counter: 222
Mileage: 0 km
Time Indication: 0
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.135 H08 1901
VCID: 3561029B5C7C7BE90A-8060
4 Faults Found:
00668 - Supply Voltage Terminal 30
Freeze Frame:
Mileage: 207550 km
Temperature: 32.0°C
Voltage: 17.50 V
Voltage: 17.30 V
00625 - Vehicle Speed Signal
013 - Check DTC Memory - Intermittent
Freeze Frame:
Mileage: 207550 km
Temperature: 32.0°C
Voltage: 18.70 V
Voltage: 18.50 V
00003 - Control Module
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Freeze Frame:
Freeze Frame:
Mileage: 207600 km
Temperature: 41.0°C
Voltage: 9.50 V
Voltage: 9.30 V
Address 46: Central Conv. Labels: 3C0-959-433-46.clb
Component: KSG PQ46 RDK 051 0221
Coding: 13910F8001860E767404141FF08A0F0E087800
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.clb
Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
Component: J387 TUER-SG BT 1131
Revision: 32008001 Serial number: 00000008978509
Coding: 0001204
VCID: 3C7717BF7F56AAA1F5-8068
1 Fault Found:
00933 - Electric Window Motor; Passenger Side (V148)
Freeze Frame:
Fault Status: 00100101
Fault Priority: 3
Fault Frequency: 3
Reset counter: 7
Mileage: 207295 km
Time Indication: 0
Address 53: Parking Brake Labels: 5N0-907-801.clb
Part No SW: 3C0 907 801 J HW: 3C0 907 801 J
Component: J540 EPB3 VW-09393 0009
Revision: 008 Serial number: 00000000015067
Coding: 0000057
VCID: 2959DEEB80C42F099E-807C
2 Faults Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 2
Reset counter: 222
Mileage: 207609 km
Time Indication: 0
Date: 2017.05.16
Time: 02:44:09
Freeze Frame:
Voltage: 8.10 V
Count: 50
Speed: 14.0 km/h
Hex Value: 0x1260
Hex Value: 0x0004
Hex Value: 0x0101
Freeze Frame:
Fault Priority: 1
Fault Frequency: 2
Reset counter: 222
Mileage: 207609 km
Time Indication: 0
Date: 2017.05.16
Time: 02:44:09
Address 56: Radio Labels: 1K0-035-161.lbl
Part No SW: 1K0 035 161 C HW: 1K0 035 161 C
Component: Radio DE2 014 0019
Revision: 00014000 Serial number: VWZ4Z7G6246816
Coding: 0040401
1 Fault Found:
01305 - Databus for Infotainment
014 - Defective - Intermittent
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.clb
Part No SW: 1K0 959 703 Q HW: 1K0 959 795 J
Component: J388 TUER-SG HL 1118
Revision: 12006001 Serial number: 00000001659669
Coding: 0001168
VCID: 3E731DB7694AB8B1DB-806A
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.clb
Part No SW: 1K0 959 704 Q HW: 1K0 959 794 J
Component: J389 TUER-SG HR 1118
Revision: 12006001 Serial number: 00000001719316
Coding: 0001168
VCID: 3F8D60B36E40B1B9D0-806A
End-------------------------(Elapsed Time: 02:03)--------------------------
Ross-Tech: Home
6 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 206412 km
Time Indication: 0
Date: 2017.03.19
Time: 20:38:01
Freeze Frame:
RPM: 844 /min
Load: 24.3 %
Speed: 0.0 km/h
Temperature: 87.0°C
Temperature: 59.0°C
Voltage: 10.033 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 206412 km
Time Indication: 0
Date: 2017.03.19
Time: 20:38:01
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 255
Mileage: 207287 km
Time Indication: 0
Date: 2017.05.01
Time: 16:35:41
Freeze Frame:
RPM: 858 /min
Load: 27.8 %
Speed: 3.0 km/h
Temperature: 73.0°C
Temperature: 38.0°C
Voltage: 8.509 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 255
Mileage: 207287 km
Time Indication: 0
Date: 2017.05.01
Time: 16:35:41
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 207611 km
Time Indication: 0
Date: 2017.05.16
Time: 01:39:13
Freeze Frame:
RPM: 836 /min
Load: 24.3 %
Speed: 0.0 km/h
Temperature: 69.0°C
Temperature: 38.0°C
Voltage: 9.779 V
P1250 - 008 -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 207611 km
Time Indication: 0
Date: 2017.05.16
Time: 01:39:13
Coding: 0000584
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 9
Reset counter: 0
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 9
Reset counter: 0
Mileage: 0 km
Time Indication: 0
Coding: 0000348
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 9
Reset counter: 222
Mileage: 207611 km
Time Indication: 0
Date: 2017.05.16
Time: 01:16:51
Freeze Frame:
Speed: 0.0 km/h
Hex Value: 0x0002
Voltage: 10.75 V
Bin. Bits: 00111110
Count: 170
Freeze Frame:
Fault Priority: 3
Fault Frequency: 9
Reset counter: 222
Mileage: 207611 km
Time Indication: 0
Date: 2017.05.16
Time: 01:16:51
1 Fault Found:
Coding: 00046997
Shop #: WSC 00028
9 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 97
Reset counter: 222
Mileage: 199129 km
Time Indication: 0
Date: 2016.08.15
Time: 12:28:00
Freeze Frame:
ON
Voltage: 12.90 V
ON
ON
OFF
OFF
ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 97
Reset counter: 222
Mileage: 199129 km
Time Indication: 0
Date: 2016.08.15
Time: 12:28:00
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 5
Mileage: 207555 km
Time Indication: 0
Date: 2017.05.14
Time: 14:20:00
Freeze Frame:
ON
Voltage: 17.00 V
ON
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 5
Mileage: 207555 km
Time Indication: 0
Date: 2017.05.14
Time: 14:20:00
Freeze Frame:
Fault Priority: 1
Reset counter: 222
Mileage: 199101 km
Time Indication: 0
Date: 2016.08.14
Time: 01:27:00
Freeze Frame:
ON
Voltage: 13.40 V
ON
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 1
Reset counter: 222
Mileage: 199101 km
Time Indication: 0
Date: 2016.08.14
Time: 01:27:00
Freeze Frame:
Fault Priority: 1
Reset counter: 222
Mileage: 199101 km
Time Indication: 0
Date: 2016.08.14
Time: 01:27:00
Freeze Frame:
Fault Priority: 1
Reset counter: 222
Mileage: 199101 km
Time Indication: 0
Date: 2016.08.14
Time: 01:27:00
Freeze Frame:
Fault Priority: 1
Reset counter: 222
Mileage: 199101 km
Time Indication: 0
Date: 2016.08.14
Time: 01:27:00
Coding: 0012599
1 Fault Found:
Coding: 0001013
Coding: 0005205
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 7
Mileage: 207295 km
Time Indication: 0
Date: 2017.05.01
Time: 17:06:40
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 5
Mileage: 207554 km
Time Indication: 0
Date: 2017.05.14
Time: 14:19:41
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 244
Mileage: 207354 km
Time Indication: 0
Date: 2017.05.06
Time: 19:59:21
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 244
Mileage: 207354 km
Time Indication: 0
Date: 2017.05.06
Time: 19:59:21
Coding: 0001205
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 222
Mileage: 0 km
Time Indication: 0
4 Faults Found:
Freeze Frame:
Mileage: 207550 km
Temperature: 32.0°C
Voltage: 17.50 V
Voltage: 17.30 V
Freeze Frame:
Mileage: 207550 km
Temperature: 32.0°C
Voltage: 18.70 V
Voltage: 18.50 V
Freeze Frame:
Freeze Frame:
Mileage: 207600 km
Temperature: 41.0°C
Voltage: 9.50 V
Voltage: 9.30 V
Coding: 0001204
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 7
Mileage: 207295 km
Time Indication: 0
Coding: 0000057
2 Faults Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 2
Reset counter: 222
Mileage: 207609 km
Time Indication: 0
Date: 2017.05.16
Time: 02:44:09
Freeze Frame:
Voltage: 8.10 V
Count: 50
Speed: 14.0 km/h
Hex Value: 0x1260
Hex Value: 0x0004
Hex Value: 0x0101
Freeze Frame:
Fault Priority: 1
Fault Frequency: 2
Reset counter: 222
Mileage: 207609 km
Time Indication: 0
Date: 2017.05.16
Time: 02:44:09
Coding: 0040401
1 Fault Found:
Coding: 0001168
Coding: 0001168
