1 - 7 of 7 Posts
my friend has a jl 12" w7 and a 1000 watt rf amp whenever his sub hits at full strength all his lights dim. would a capacitor fix this problem?? if so how many farads???
You can fix that with a capacitor, one you should get is a 1 farad cap. .They typically run a little over a hundred dollars. Seems that crutchfield has them pretty cheap, or you can go to best buy.
No, a cap won't fix this. If the voltage drop is bad enough to be visible on the headlights a cap (unless it's one of the big ass Alumapro caps) won't help. You have two options, 1) buy a bigger alternator or 2) buy a Jacobs Accuvolt. I would do the alternator personally. What kind of car does your friend drive?
Paul :thumbup:
for the cost of a capacitor I always recommend an extra battery. This will provide much more reserver power for his large jl amplifier, and should help his voltage stay up higher. It is different altogether than a capacitor because a capacitor will discharge instantaneously and then recharge, as opposed to a battery that is slow to discharge and recharge. But the good thing about a battery is that it strengthens the system in more aspects than just instantenous power needs, and he will be able to pound the streets longer and louder.
But when the car's running the battery is a load, just like the amp. It WILL help a bit, but a bigger battery will only really help when the enging is off. I'd still look at a bigger alternator or have the current unit rewound.
Paul :thumbup:
1 - 7 of 7 Posts
