Finished up doing the timing belt/thermostat/waterpump and a hand full of other maintenance items on this 2000 Passat 4motion I bought for $300. I flushed the heater core and did a full flush including the block, and now I'm trying to bleed the system but having big problems. I found some other threads describing exactly my problem, little or no heat at idle, great heat at 3-5k rpm. Everything I see says its air in the core, but I can not get it to bleed out. I've gone through $50 in coolant and don't want to waste any more.
My process so far:
cap off coolant reservoir, core bleeder open, engine at operating temp, rev engine several times.
At idle I tried pulling the hose off the core and I wasn't getting any flow from the bleeder side of the core at all at times, and just a trickle at others. I'm really at a loss at this point, what am I doing wrong?
My process so far:
