I bought a pre-owned 2002 Passat 1.8T with automatic transmission and have changed the engine oil and filter three times now. Four quarts of oil has been too much each time.
The first was at a fast lube service. Four quarts was added, and the dip-stick reading indicated overfill.
The second I did myself. I had to quit adding at a little over 3.75 quarts.
The third I did myself, draining the oil by using a Mityvac Evacuator. Again, I had to quit adding at about 3.75 quarts. I did not remove the lower engine cover and open the drain plug after using the Evacuator to see if any oil was left.
The car was driven to operating temperature and placed absolutely level prior to draining. The new filter was filled to near capacity. The oil level was checked after driving for at least one day, and more oil was added as needed.
Is this normal? The instructions say use 4.3 quarts with an oil filter change.
Should the car be placed at an angle to drain the oil through the drain plug?
With the Mityvac, should the car be placed at some angle? (The Mityvac did a good job on our 2002 Mazda Miata. Only two or three tablespoons of oil drained from the plug when I tested it.)
I hope this hasn't been discussed (too much) previously. I searched, but did not see anthing similar.
Thanks,
Mike
Thanks,
Mike
