81 - 100 of 142 Posts
Discussion Starter · #82 · (Edited)
Duh, I looked into the service manual, and funny, they tell you where to put the RTV (Sealant AMV 174 004 01)
103009
Bearing cap installation too...after the chain is on the cams, at 16 links with the CCT in between...
103008
Install bearing caps
  • Install bearing caps - 2 - and - 4 - for both camshafts according to markings.
  • Intake camshaft: Casting marks point toward drive chain
  • Exhaust camshaft: Casting marks point toward exhaust manifold side
  • Fasten caps alternating diagonally and then tighten them to 10 Nm (pay attention to alignment pins).
  • Install both bearing caps - 1 - on chain sprockets of intake and exhaust camshafts.
  • Remove bracket tool for chain adjustment 3366.
  • Check whether camshafts are correctly adjusted:
So that both markings line up, turn camshaft slightly back or forth if necessary. The ‘turn back’ part was interesting.
103007
Only then:
  • Install bearing caps - 0 -, - 3 - and - 5 - and tighten to 10 Nm (pay attention to alignment pins).
  • Tighten camshaft adjuster - arrow - to 10 Nm (pay attention to alignment pin).
Discussion Starter · #83 ·
Lost images somehow - I’ll update in a bit
Discussion Starter · #84 ·
Going ahead with advice to remove oil pan... afraid to find out how much RTV is INSIDE the pan floating around and gumming up the oil uptake
102982
Reactions: PZ
Discussion Starter · #86 ·
Ok, first pleasant surprise- doesn’t look too bad??
102984
102985
Well that's good.
No visible fractures on lower pan either. At least from the picture. Kinda crusty on the bottom side of that upper oil pan.
I'd cleanup the lower pan, slap it back on and give that engine a serious Sea-Foam treatment or two. You should be ready to go then.
Discussion Starter · #88 ·
Commence reconstruction.. this is as fas as I’ll clean it manually
102986
102987
That’s a mighty clean undercarriage ya got there, bud.
Reactions: Rob.Achmann
Discussion Starter · #90 ·
It’ll get better with a few more oil changes. I’m not one for additives - just natural clean oil with many changes
Reactions: Tomvw
before you button the top end(s) up post pic, best possible of cams and chain relationship, a good pic will tell all the viewers if 16 links is confirmed. I am sure you have seen the Ross-Tech illustration as well. Looking real good !!!! Real Good !!
1: A thin film will not hurt, but not needed.
2: Yes.
3: Only on the ends.
4: Yes on the ends, no oil or sealant around the cap.
5: No
6: Yes
I hope your self-esteem has improved now :p
Discussion Starter · #93 ·
I did fish out some old (and really old - perhaps original red sealant) silicone from the oil pickup with a skinny pipe cleaner.
103014
Discussion Starter · #94 · (Edited)
FCP does fulfill their warranty promise - my new tool:
103015
and finally got the shoes in:
103017
and picked up non-chlorinated brake cleaner for half price today!
103018
Ladies & Gentlemen, it’s assembly time!
Reactions: VAGguy
Discussion Starter · #95 ·
Put up the lower oil pan - but I remember reading that for RTV, you finger tighten ( about half torque, and then after an hour, torque it up to spec... correct?
Discussion Starter · #96 · (Edited)
Bloody double hockey-sticks, those new shoes are hard to get on!!
now I’ve got a predicament- which is bank one and which is for bank 2... let me see if I can tell from pics...
103019
got it... 087 C is bank 2
078 109 088 BANK 1
078 109 087 BANK 2
Discussion Starter · #98 ·
Ok, how do you get the cams to sit in the head properly? How do you install a cam? The cam followers push up on the cam so it can’t sit properly. Do you have to push down on the cam to push in the followers? Cam you use the bearing caps to ‘pull’ the cam into its seat?
103020
Discussion Starter · #99 ·
I think I got it. In the repair manual, it said to install the cam off TDC - then rotate back to set the cam followers properly
I usually use the "cam caps" to draw the camshaft down. But...
You have to work your way back and forth on the camshaft so you don't bend it.
With all of the screws finger tight, start at one end of the camshaft, working towards the other end, turn all of the screw like 2 turns. Repeat process until camshaft is fully seated.
Before you go any further. Make sure you've got some lithium grease or at the very least copious amounts of clean engine oil around all the cam bearing journals.
