Ok, but where would I put that? In the cam journals? On the cam followers?Friendly Local Auto Parts Store. It was probably more of a thing before Amazon...
The chain does wear, however so miniscule, so insignificant not even worth thinking about, the shoes are way way more a factor. Theoretically, since the shoes and springs are designed to balance/center the system , any stretch is equal in the tops section and the bottom section of chain therefore, stuff still remains centered.Yeah, makes sense. Sh*t, this is cool stuff. The chain does see some pressure, so it must stretch over time? What’s the lifespan of the chain? 400K km? Sooner? ie- when should one think about replacing it?
they snap on and off.....tightly........or in APs case they wear off "pores/bubbles" that is for oil retention, lol, as a side bar not sure what the material is, what they are made of, seems like a phenolic or some other top secret, project x thermoset material, whatever it is it is definitely wear resistant considering the environment they operate in.So, how does one get the pads off?
Probably, they’re the last stop in world of plastic polymers; nylon. Tough as nails, and 100% un-recyclable.they snap on and off.....tightly........or in APs case they wear off "pores/bubbles" that is for oil retention, lol, as a side bar not sure what the material is, what they are made of, seems like a phenolic or some other top secret, project x thermoset material, whatever it is it is definitely wear resistant considering the environment they operate in.
Well, for the last 5 years before I owned the car, I saw it across the street and knew the owners. While a fantastic neighbour and who had become a good friend, he refused to do anything to any of his cars. Since it was leaking oil, he put so much in that he probably thought it was as good as an oil change. Type of oil? If the bottle said motor oil, that was good enough for him. I wouldn’t have been surprised if an oil test found 2-stroke in there. When I got the car, it was in awful shape, sounded like a cornered raccoon when it did drive, and could barely get up to 90Kph. He even had green gas station coolant in the trunk, just in caseYour pads are badly worn because dino oil was used, use only the correct full synthetic oil.
I'm not for certain by any means but my guess (based on what I've seen in the industry) it might be a glass filled cast 6/6 nylon. Tougher than moon rock and very heat resistant.Probably, they’re the last stop in world of plastic polymers; nylon. Tough as nails, and 100% un-recyclable.
