How does one get to the bulbs in the cabin lights specifically the ones for the rear passengers? TIA for your help. :bow:
I can help you out with this one (someone else's pics)
this is the left rear light if your facing the front of the car
Lift the circled part (it will only lift about 5mm) stick a flat head screw driver in the slot and push the metal clip in (toward the back of the car)
(pretend the red line is the roof)
To sum up, stick a flathead perpendicular to the end of the light. Push the screwdriver inwards, pull the light downwards.
Great post! I am compliing a huge folder of jpegs on lights for the Passat and how to change'em. I spent a hour on the weekend figuring out how to remove the taillight bulbs from my wagon. Not that hard but it's so easy to break a plastic tab or something if you don't know what you're doing.
Thanks :thumbup:
