Building a Trailer
637 Views 5 Replies 4 Participants Last post by  ganseg
I have access to the rear 'axle' off a Jetta, and I am wondering if I could use it to make a trailer. And if so, any ideas on lighter springs since i won't be carrying around 1,000+ lbs? Thanks.
I bet you could figure something out on using it.
I would probably get a set of cheap air shocks and use those as springs.
Yo! I like the air idea - maybe air adjustable springs!
not sure what you want the trailer for? i suggest you save yourself ALOT of $$$ and time and just buy a trailer.
unless you are just bored.....then knock yourself out!
good luck.
i did a search of vw trailers; also here is the bmw trailer, maybe you could get some ideas from it. For springs I'd do the leaf spring setup like most trailers.
Those last two are sweet! The trailer is for light hauling. Our 5 bikes, brush, supplies for house projects. Maybe someday it would get used for an ATV, but I don't know if that's too much weight for a trailer that would work well for the light stuff I know I will be doing.
