1 - 7 of 7 Posts
While trying to see if I could get better access to the back of the driver’s side head via the wheel well (no you can’t), I noticed something else that won’t pass inspection... a broken spring...wow How is that even possible?
100348
You need to lose weight :)
That’s salt’s doing. Where was the car driven most of its life?
I’m guessing here in NB, but not entirely sure of history.
That’ll do it. It seems to be happening more often lately.
Reactions: cchief22
If you only need to pass inspection, raise the front of the car on jack stands (looks like a front spring). Then slide the broken spring up until it clears the shock body. There should be enough of a gap on the spring to pass the shock piston.
If you want to replace it, they are best done in pairs. Most GLX springs will switch over, but I would get ones from a Tip trans to match the weight better.
Rob, can you make out the color markings on that spring?
Reactions: axenstar
OH, it's definitely possible!
Mine did the same thing (2002 GLX AWD wagon) Heard a clunk while driving, then the nose dropped.
I'm going cheap and swapping the ones from my parts car (2005 TDI wagon)
1 - 7 of 7 Posts
