1 - 7 of 7 Posts
I just installed the new HID looking headlights sold by Cullen. I also installed the Euro switch.
My headlights will only go on "bright" when I pull, and hold, the stalk. If I push the stalk forward to the normal "bright" position the lights just stay on low beam.
Did I do something wrong on the install? or is there some incompatibility issue with a 99 1.8T Passat
Possibly the high beam switch needs to be replaced but you never noticed.
Or it could be that you have not connected something properly.
oddly enough I had this same problem when I installed my euroswitch. Do you have the DRL's disabled by pulling relay 173?? I reinstalled my relay and cycled the euroswitch then removed it again. Along the way I also put my stock switch back in to check if the HB worked with it. Some how it "reset" itself and when I put the euroswitch back in and then pulled the relay back out... everything worked like it was supposed to.
I'm not sure why this worked....
Just my experience.
I had this problem too, then I found out that I had to move the euro switch knob all the way to the right. Problem solved!
:lol: :lol: :lol:
that's funny , but why you guys call it euroswitch if you are in Europe...
You should call it standard switch ...
hmmm. I don't have a Euroswitch, but my HB ony work when I pull back on the switch. And my lights are on at the time.
Should I try to put my DRL relay back in and try?
1 - 7 of 7 Posts
