My wife's 1999 Passat calls for a 195/65-15 H rated tire. After reading this forum, I have decided on the Turanza.
Nither my wife nor I are aggressive drivcers. Most all driving is 5 - 10 miles around town, with a few occasional trips of ~350 miles.
Is there any reason I shold not purchase the LS-T rather than the recommended LS-H, e.g. a safety issue? I understand the LS-H will hold corners better, but given the type of driving we do is this really an issue?
Better cornering is only part of the deal. Better braking,less hydroplaning,better emergency handling and
better heat resistance (not sure where you dirve). The LS-H is quieter also. They might have nearly the
same name,but they are nowhere near the same tire.
I have the LS-H on my Passat and the LS-T on a Taurus wagon and a Subaru Impreza. In your case,you
will probably be fine with the LS-T,but you need to watch your speed and air pressure on distance driving.
PZ.
PZ,
Thanks for your feedback. some follow-up ...
RE: not sure where you dirve
I live in Southern NH. While we get a fair amount of snow, the towns do a very good job of keeping them clear, thus it is also very infrequent when we are driving in these conditions.
RE: In your case,you will probably be fine with the LS-T,but you need to watch your speed and air pressure on distance driving.
75 - 80 MPH is tops for me. For tire air pressure, is assuring VW recommended pressure sufficient, or where you thinking of something else?
I recently purchased the Bridgestone Turanza LS-Hs (205/60-15s) for my '98 Passat 1.8T, and have been very pleased with the tire's performance on dry, wet, and snowy roads (2-4 inches of snow). Also, the tires are very quiet on the highway. Love these tires.
Kevin
Not sure how good the LS-T would be in snow. Just looking at the tread,I would go with the LS-H. More
edges,generally better in snow.
As far as pressure,I would not run anything under 32. T rated tires do not tolerate heat nearly as well.
Low pressure will heat them up. Of course,up there it does not get nearly as hot as here (TX).
PZ.
