Yes, it will help keep them quiet. Worked on mine for over a year and on another set I installed on a BBK.
Got it done, :salute: - no bark from the car & no attention grabbing squeal - I pray for the quietness last longer than yours.Yes, it will help keep them quiet. Worked on mine for over a year and on another set I installed on a BBK.
I will double check next time when I get a chance. I am probably fine as I apply the paste per instruction (which reads "apply liberally" ) and then left it to cure overnight.You put that on a bit thick. Make sure it did not run over the edges onto the slide area of the caliper carrier. If it reaches the carrier, the brakes will drag.
