I took advantage of some warm weather yesterday and washed my 2000 V6. This morning I noticed the brake lights are not working!
Does anyone have a fuse location for the brake lights? I pulled all of the lower amperage fuses (5A) and they all look fine.
Thanks in advance,
-tF
If you pull the fuse cover off, there should be a legend on the inside of the cover that shows what each fuse is for. You sure it's not the bulbs? I've got a 2000 V6 and I just replaced one of the brake light bulbs yesterday. Very easy to replace, took all of ten minutes.
Thanks, but my fuse panel just has "cartoon pictures" for each fuse location so I'm not sure which is specifically the brake lights. So much for international signage...
