Hi All, I have been trying to replace my brake booster in my 2022 VW Passat AWM but have been having issues. The original brake booster failed due to water infiltration. Whenever it was freezing out, the water would freeze and prevent the brakes from working correctly. I replaced with a CARDONE 532947 remanufactured brake booster but am still continuing to have issues unrelated to the original problem. I have bled the brakes and done everything correct to the best of my knowledge. I get a hiss from the brake booster whenever I push down on the pedal. The engine stumbles and gives all indications of a vacuum leak. The brakes work but I need to push much harder than I should need too. Its obvious the booster is still not working as it should. I sprayed brake cleaner everywhere I could think of to test for a vacuum leak but I was unable to locate. Is it more likely the part is defective or am I missing a step in the process? Any suggestions or guidance would be appreciated.
