OK so the flex plate and the torque converter and that gasket or whatever the metal plate thing that goes between the transmission and the engine right? So the metal plate thing got bent out of shape now the bolts that hold the torque converter and the flexplate together the three that I asked about what the torque specs are in a different post? Anyways they are rubbing against that plate how bad is this? Can I still safely drive it or should I replace that plate before I do anything at all? Need to know asap
