Here is the problem (2007 B6 Passat 2.0T Wagon):
Blower was working fine when it went in to see why my AC wasn't cold (bad compressor, hasn't been replaced yet, spins but something broke internally). The fan stopped working while at the shop. It does not work in any speed so I pulled the glove box, hooked 12V to the fan and it works fine.
I checked the fuses and they are all good from what I can see, it's ridiculous hat you can't actually get a correct fuse diagram or the car.
Since the fan doesn't work at any speed, ruled out the resistor network (is this correct?
Next thing would be the switch? How the heck do I take apart the dash to pull the contol switch assembly / check anything on it?
Any other ideas? Is there a relay that could be bad or something?
If it is the switch, any idea where I can get a new switch for a good price? The ones on the tuning website in another thread are not the climatic ones I have.
Kevin
Kevin
