01 V6
2 questions
My brother accidently stripped the hex insert to the coolant bleeder screw closest to the front of the motor :thumbdown
Do I have to be able to use this particular bleeder point so long as I bleed from the other (the one closer to the firewall) and the one on the heater core? I don't want to have to spend $ on the replacement because I'm selling the car.
While replacing the oil cooler I accidently broke the little plastic parts that hold the plastic tube/ sleeve and the rubber gasket together as one piece but now I can remove the plastic tube by itself. The other 2 longer plastic pieces are still fine.
Do I need to send the cooler back for a replacement or is it no big deal.
Thank you
Are you sure he actually stripped it? I thought I had but then I noticed there was some crud in the bleeder allen key hole. I used a pick to clean it out and the key went in much further than before and I was able to open it. See if you have the same thing.
I was able to loosen it by angling the Allen key a bit and putting a bit of pressure on it. :thumbup:
As far as the part I tried describing that I broke it doesn't appear to have effected the oil cooler and its function :bowdown:
