Has anybody tried fitting the NAPA Gold "Big Kahuna" #1333 oil filter on the V6 ATQ engine?
I compared the relevant specs on the Big Kahuna 1333 filter to the #1355 filter that NAPA specs for the V6 ATQ engine. These are the results:
FIL #1333
Gasket ID - 62.54 mm
Gasket OD - 71.98 mm
Filter Height - 177.34 mm
Filter OD - 93.22 mm
Flow Rate (@19 micron) - 7-9 GPM
Thread Size - 3/4 -16
FIL #1355
Gasket ID - 62.36 mm
Gasket OD - 69.98 mm
Filter Height - 113.67 mm
Filter OD - 95.12 mm
Flow Rate (@24 micron) - 7-9 GPM
Thread Size - 3/4 - 16
It appears that the difference in the gasket ID/OD measurements may cause the Big Kahuna 1333 to leak when installed on the V6 ATQ engine?
Doing the math...
The NAPA Gold Big Kahuna #1333 filter provides ~35% additional filter area over the NAPA Gold #1355 oil filter that NAPA specs to the V6 ATQ engine.
If I could add 35% more oil filter area, and increase filtration granularity from 24 microns to 19 microns, by using the Big Khauna 1333 oil filter on the V6 ATQ engine - and have confidence that the filter won't leak - I would definitely do it.
:wrench:
Cheers!
FIL #1333
FIL #1355
Doing the math...
:wrench:
Cheers!
