Picked up a basket case 2003 1.8T. The PO tore into it pretty good (removed the head) and started to put it back together but didn't finish. I pulled off the radiator to check the timing just to make sure it was all good, there were several screws and bolts missing in various places and the timing belt tensioner bolts were finger tight, among other things, but the bottom line is that I don't really trust the work that was done. He did tell me (and I asked specifically) if he used a new head gasket and new head bolts. He said that he did, and he claimed to do the torque pattern as directed also. The car started and ran, not well, but ran when I got it. None of the cooling lines are hooked up and some are missing and also a bunch of the vacuum lines are unhooked as well so it didn't run good or for very long either, but did run.
So heres my question. Is there a way to tell if the head gasket is put on properly (not upside down), just by looking at it? I know there are a couple tabs that stick out past where the head and block come together, but not sure if they would be oriented in the same place if the gasket is right side up or upside down. I don't really want to pull the head again if I don't have to.
The whole reason he pulled the head was because there was oil in the coolant, so basically he did it for no reason in the first place. If the gasket was actually blown, I probably would pull the head just to make sure it wasn't warped or cracked, but that was not the case. He ended up figuring out it was the oil cooler after the fact, so that is new also.
Thanks.
Thanks.
