Hi folks,
I'm at the end of my tether with my DPF. Had it removed and cleaned after having new pressure sensor fitted, new thermostat fitted too. I have had the car for 3 years and didn't once see the DPF light come on and now it seems to refuse to regenerate on the roads around here. I tried to do a forced regen today but the car won't rev or heat up even when it says the regen is running. Anything obvious that may be my problem other than the dpf is just knackered? The car is a 2011 2.0 tdi 140hp. I'd rather not go down the Rd of getting the dpf taken out and deleted from ecu. Any help much appreciated
