1 - 2 of 2 Posts
Both seat heaters work, passengers seat's switches all work. The driver's seat has never worked since purchasing it used. It didn't come with the fuse panel diagram, so I just pulled every fuse and they're all good. I think it might be the the driver's side power seat control module, but don't know how to test it and the passengers doesn't swap over :( The part costs 150. used making it a bit pricey to buy and see if it does the trick. I have pulled the module out opened it and checked for scorch/damp marks or other obvious signs of failing components.. It looks really good.... Any help will go a long way please and thank you!
Discussion Starter · #2 ·
Update! I replaced the power seat memory control module, and now the seat is working!! I bought it used on ebay.. the cereal number matched almost perfectly and it didn't require any coding to make it function.. plug and play!
1 - 2 of 2 Posts
