Hi my B6 Passat (2006) 2.0t Canadian, has just had its instrument cluster tested and is dead, I would like to try replacing it myself, I have the VCDS stuff idk if that would help, essentially wondering if this is possible to do at all? Does it have to be a brand new cluster? Is all I need Is a new cluster? My main concern is getting a working one but if I can upgrade for equal to just slightly more effort I would like to know if that is possible as well thank you!
Also wondering if clusters can be opened up and the broken connections or gauges repaired thank you.
M’y cluster part number - VW3C0920870 R i think this is my part number at least not sure tho
those clusters can be repaired , I also believe they can be up graded.....I know the B5's display fades and those can be sent out and repaired , go to "search community" and search might not be a ton on the B6 but if you query; "display fading" you might get the answers you are looking for.
