Hello.
I have a b6 passat wagon 2.0tdi 136HP CBA model (made for Belgium market) with 257xxx kilometers/160000miles and i figured out i need more HP
As i watch on TV and read on forums a lot of people around the world know a lot of car mods and tuning so i need advices/help.
I was thinking if i can change my engine nozzles with Audi 3.0tdi engine nozzles and my turbo with audi 3.0 turbo?
Is this plug and play or? How do i know which one nozzles fit etc.?
Is there anything else i should change while doing installing this mods? For clutch and flywheel i know. I don't hear them but new is new.
After this engine mods i need to put bigger brake discs to stop all this horses yes?
I was already thinking about lowering a car with JOM coilovers.
Do i need to upgrade wheels and tyres to? now i run 16'' :D
I'm a beginner so i really don't know how to ask and where to start.
thank you
Discussion Starter #2
Forgot to say it's FWD. Hom much can i put power on FWD?
And i think i just realized that i cannot put audi nozzles in but i should change my nozzles for the nozzles from b6 170HP engine. yes?
You should look for local chipping companies. With a remap, you can add a good amount of power. Larger injectors and turbos should only be considered if you would not be content with a remap.
Actually nozzles should be the first choice. If you do a tune first and then go to bigger nozzles you'll have to get a new tune done for addition costs. Same applies to a bigger turbo.
On my Passat I just did the Malone Stage 2 tune and the result is what I wanted. I have no intentions to change nozzles or the turbo.
Oh ok. I'll wait with a remap till flywheel says goodbye so i can change it and than remap. Thank you for your reply
I'll see what i will do. I'm not sure yet. i have few other projects to finish first. thank you for your reply
