1 - 3 of 3 Posts
does anyone know the difference between the pro kit springs for a B5 vs B5.5? they are listed as two different part numbers on the Eibach website but i didn't think there was a difference in the suspension between the two body styles...
thanks in advance,
Andy
Discussion Starter · #2 ·
i just called Eibach and they said it's a totally different spring rate, but they didn't say what the rates were.
can anyone verify this? i didn't think there was that much of a weight difference in the two cars to necessitate a totally reworked spring set up.
Well I run B5.5 springs on my B5. the B5.5 has alittle extra weight so the B5.5 will be stiffer then the B5 but you can swap ether or....just not the motors. Always stay with the same motor
1 - 3 of 3 Posts
