Will the strut brace fit a b5.5?Is it new? If not, how old? Thanks
You remove the bolts, place the strut bar in place, install the bolts without the washers.How is that attached to the strut towers? Any pics of it installed? Dibs after pablo.![]()
That's how you do the A6 bar, but this design is different. It appears to have a single mounting point and I needed a visual because I may have a potential clearance problem from the SC blow-off valve plumbing. :wrench:You remove the bolts, place the strut bar in place, install the bolts without the washers.
