1 - 2 of 2 Posts
I've lined up all marks and have had the valve covers off to verify timing between the cams by counting the links.
EVERYthing was checked and rechecked several times before starting. The car runs but badly with misfire codes on cylinder 1/3/4/6. But nothing on 2/5.
After it was running, I set the engine back to TDC and all marks lined up still.
Things I also replaced during the TB job:
-Spark plugs (put the wires back in the right spot)
-Timing Chain tensioner/gasket
I'm at a loss here. I don't know what would be causing multiple misfires if everything is set correctly.
1 - 2 of 2 Posts
