1 - 2 of 2 Posts
I have the following led bulbs fitted and working fine...side lights, no plate lights, reverse lights and side indicator repeater lights. I have bought front and rear led indicator bulb but they flash rapidly as tho a bulb has blown, is there anything I can do to fix this so they work?
Thanks in advance
Steve
Did you check all your fuses? Try putting in a the same bulb from another side and see if the problem switches sides
1 - 2 of 2 Posts
