Couple of quick questions I'd appreciate some feedback on.
I have an 03 GLS (5spd) with the V6 with 237k miles.
Today was the coldest day of the year so far (7F) and I've been having some coolant issues.
1. what type of bolt holds the auxiliary water pump on: is it a hex (like a 10mm or an allen (anyone know?) I'm trying to remove it without disassembling a bunch of things in the way and can't see the head.
2. I bypassed the heater core last month with a U shaped bypass heater hose because the leaks from the inlet and outlet pipes were getting worse and I don't have time to tear apart the dash to replace the heater core. One is missing a 2" x 1/4" wide section down the length of it. I found some high temp/pressure water safe fiberglass tape--has anyone ever tried repairing those pipes? Maybe a sleeve of some sort with heavy amounts of epoxy?
TIA
tape was like this item but smaller quantity/less money: https://www.amazon.com/Perma-Wrap-Pressurized-Pipe-Repair-Kit/dp/B00KS6GLF4/ref=sr_1_19?ie=UTF8&qid=1548113988&sr=8-19&keywords=fiberglass+pipe+repair+tape+water
TIA
